En primer lugar se crea un plano donde se generan particulas estaticas (ver imagen 01)
Amount es el numero de particulas que se generan, se puede modificar este valor para variar la cantidad de particulas que necesitamos.
Imagen 01
![Imagen](1.-%20Creamos%20un%20nuevo%20material%20que%20contengan%20una%20textura%20blend,%20activamos%20el%20boton%20%5C%22color%20band%5C%22%20y%20modificamos%20los%20colores%20para%20tener%20una%20gama%20de%20verdes,%20se%20pueden%20agregar%20mas%20colores%20en%20el%20boton%20%5C%22add%5C%22,%20aqui%20es%20importante%20que%20el%20ultimo%20tono%20del%20lado%20izquierdo%20sea%20alpha%200,%20para%20que%20tengamos%20un%20terminado%20transparente%20al%20final%20de%20cada%20pasto.%0A%0A2.-%20En%20las%20caracteristicas%20del%20material%20activamos%20%5C%22ztransparent%5C%22%20y%20en%20%5C%22strands%5C%22%20modificamos%20los%20valores%0A%0Astart,%20es%20valor%20de%20inicio%20de%20las%20particulas,%20en%20este%20caso%20es%20%207.000%0AEnd,%20es%20valor%20final%20de%20las%20particulas,%20en%20este%20caso%20es%201.100%0A%0AShape,%20modifica%20el%20ancho,%20en%20este%20caso%20es%20.400%0A%0AModificando%20estos%20datos%20puedes%20obtener%20diferentes%20resultados.%0A%0A3.-%20En%20las%20caracteristicas%20de%20la%20textura%20en%20la%20seccion%20Map%20Input%20activamos%20los%20botones%20%5C%22Strands%5C%22%20y%20%5C%22Flat%5C%22.%20En%20la%20secci%C3%B3n%20Map%20to%20activamos%20los%20botones%20%5C%22col%5C%22%20y%20%5C%22alpha%5C%22%0A%0AImagen%2002%0A%5Bimg%5Dhttp%3A//www.g-blender.org/uploads/img451ae79e36f16.jpg)
Agregamos un plano inferior que contenga una buena textura y podremos obtener una imagen similar a esta.
![Imagen](Supongamos%20que%20quieres%20tener%20areas%20de%20pasto%20que%20no%20sean%20uniformes.%0A%0APrimero%20entramos%20al%20modo%20de%20edici%C3%B3n%20del%20objeto%20y%20subdividimos%20nuestro%20plano%20para%20tener%20un%20mayor%20control%20en%20la%20asignacion%20de%20los%20pesos%20%28esto%20lo%20esplico%20mas%20adelante%29%0A%0APresionamos%20%5C%22w%5C%22%20y%20escojemos%20la%20opcion%20de%20subdividir,%20se%20repite%20este%20proceso%20cuantas%20veces%20creas%20necesario.%0A%0APresionamos%20%5C%22a%5C%22%20para%20seleccionar%20todos%20los%20vertices.%0A%0AEn%20la%20seccion%20de%20Link%20and%20Materials%20creamos%20un%20nuevo%20grupo%20en%20el%20boton%20%5C%22New%5C%22,%20nombramos%20este%20grupo,%20para%20este%20caso%20%5C%22area%20sola%5C%22%20%28puede%20tener%20cualquier%20nombre%29,%20y%20asignamos%20todos%20los%20vertices%20con%20el%20boton%20%5C%22Assign%5C%22%0A%0A%5Bimg%5Dhttp%3A//www.g-blender.org/uploads/img451ae7b89bf73.jpg)
Nos cambiamos con F7 al Objet Panel y en la seccion de Particle Motion en \"Vgroup\" introducimos el nombre de nuestro recien creado grupo de vertices \"area sola\", esto indica que de acuerdo a los pesos que asignemos es donde crecera pasto.
![Imagen](Nos%20cambiamos%20a%20la%20secci%C3%B3n%20%5C%22Weight%20Paint%5C%22%0A%0A%5Bimg%5Dhttp%3A//www.g-blender.org/uploads/img451ae7d3c6570.jpg)
Presionamos F9 para entrar al Editing Panel, en la sección Paint podemos seleccionar diferentes valores para Weight.
0 es color azul y es donde no existira pasto
1 es color rojo y es donde existira más pasto
Pintamos sobre nuestro plano y podemos ver que las secciones azules no tienen pasto, por lo que podemos modificar completamente las areas no queremos que tengan pasto
Opacity es la opacidad de la brocha para pintar y size es el tamaño de la brocha.
![Imagen](Siguiendo%20estos%20pasos%20podemos%20obtener%20diferentes%20resultados%20como%20lo%20muestra%20la%20siguiente%20imagen.%0A%0A%5Bimg%5Dhttp%3A//www.g-blender.org/uploads/img451ae7ee94f19.jpg)
Anexo el documento .blend
